new cluster, tach not working
95civiccx
i just bought a cluster out of a 95 ex for my 95 cx hatch. After getting everything hooked up i went for a ride, i noticed that the tach only goes to about 4k before it is time to shift, and it does this for every gear. I thought my engines redline was liek 6500. did i screw something up when i installed it? did i get a broken cluster? is it cool that the cruise control light lights up when its time to shift?
thanks
mark
loccusst
Experienced Noob
The cruise control lights up when it's time to shift???? Sounds like you got a modafied cluster....probably why it doesn't work right.
rei
jSolo
take it out and make sure everythings hooked up right..
2000civicracer
Looking for a Civic Again
i have to agree with both of them it might be a modded cluster or you might have wired something really wrong
t3t4h22
BUY MY HATCH!!!
i doubt its an installation poroblem, kind of hard to mix up 4 plugs, especially when none of them will fit into the other plug jacks.... probably a shorted circuit in the inst cluster, or its been modded...cant see why anybody would purposely mod an ip to do that though.... :???:
Blazed
f**k The Powers That B
exactly why would some1 mod it to be lihe that..
i say a short somewhere too..
95civiccx
is there anything i can do to fix it or am i stuck with a messed up cluster?
95civiccx
correction: the tach does work it just goes up to 4500 and then i hit redline, i know my redline isn't 4500, maybe something in my car is messed up, not the cluster??
t3t4h22
BUY MY HATCH!!!
DAMN, maybe there is a domestic engine under the hood :lol: those clusters are plug-n-play (interchangable), and unless your a total ass, (which i have to assume that your not) you couldnt screw that up-----try swapping them back and seeing if it still does it-- may have another prob that came up as a coincidence....when you say you hit redline, do you mean the engine hits the rev limiter, or that is redlined on the tach? MORE INFO?...
95civiccx
well i would hit the rev limiter if i was an idiot and didn't know when to shift, so basically when the tach says 4500 my engine is going around 6500, what would changing back to the old cluster do if my old cluster doesnt even have a tach????
i emailed the guy i bought it from on ebay, i guess well see what he has to say, maybe if it shorted out we could get ups to insure it cause it was damaged in shipping??? who knows...
$lick Rick
TEOTWAWKI
20+ Year Member
and what makes you think you're at 6500rpm?
you've never had a tach in there, you have no clue what rpm you've been driving or shifting at.
as for the cruise light.... no f**king clue on that one
t3t4h22
BUY MY HATCH!!!
:shock: SELF PROCLAIMED TACHOMETER :crazy:
while you're on EBAY, search for an autometer tach or something, and if your old cluster is ok, put it back in
and while youre at it, calm down, our suggestions are for your help....no nead to get a 'tude :roll:
95civiccx
i know my redline is 6500, i know that redling of my car is 33mph, when im going 33mph in first gear my tach says 4500, which is obviously wrong and i wanna know why
t3t4h22
BUY MY HATCH!!!
maybe the speedo is off some....
i know the speedo is slightly off in my SI cluster in my CX.... :what:
5thGenCX
long gearing owns me.
my CX redlines between 5000 and 5800 depending on a number of things, cold or hot, engine load, etc. but it does redline in 1st at 34ish, maybe your crank sensor is off..
95civiccx
yeah that would make alot of sense but everywhere i check it says redline is 6500
92-95 Civic CX
D15B8 1493cc
4 cyl, 8 valve SOHC
9.1:1 c.r.
PGM-FI (MPFI)
70 bhp @ 4500
83 lb-ft @ 3000
Redline: 6500 rpm
http://www.summitracing.com/landing/sportcompact/ln_02feature.htm?ID={C26F7A1C-20D7-44B5-90FA-3A693312A715}&Type=7
Kjeldor
ok, first it says a cx redlines to 6500 but that is not true, i bought a cluster for my cx and it didnt redline near 6500, just for the fact that its a cx (my guess), next ur cx is an economy car so on ur old cluster u had the lilttle arrow pointing up and lit up everytime it was time to shift, it does this in order to get more miles per gallon. since the new cluster doesnt have the arrow, ur cruise light lights up every time its time to shift. and if u keep tryin to get ur cx to rev at 6500 i dont thinks its ever going to.
