ok I have done a few things to get my swapped car to pass, but can't pass idle emissions. A few things I know that might help.
1) I'm 2k miles past an oil change... so I need to change it to get my ppm down (pvc screwing me)
2) have a cell for knock sensor.. but have passed with it on before
Car = 92 SI hatch with B16b swap to a P73 OBD1 ECU
-cam BC stage2
-valves BC
-Short ram
- 4-1 + test pipe + full 2.5" exhaust
Readings:
Mode: Idle - fail
HC ppm reading 464 standard 220 FAIL
co% reading 0.53 standard 1.2
Co2% reading 14.1
O2% 1.6
Mode: high idle - pass
HC PPM reading 122 Standard 220 PASS
co%0.92 Standard 1.2
co2% 14.2
o2% 1.0
Thoughts?
I was thinking of throwing a 1/4 tank of 93 in it and 1 qt of denatured alcohol in it and go for just the idle test being that this is the initial test AFTER an oil change. Maybe sprat out the IACV screen with some carb cleaner?
I know it isn't a huge fail (especially with the swap)
Any ideas? Ron? c'mon buddy I know you got something in you for this minor PPM change.
-cam BC stage2
-valves BC
-Short ram
Readings:
Mode: Idle - fail
Co2% reading 14.1
O2% 1.6
co2% 14.2
o2% 1.0
Thoughts?
