Tarpon1959
All, Picked up a stock grandma driven 97 civic sedan with 128K and need to sort out a couple of things. the most pressing is a noise from the rear of the car only when going around a right turn at first. Once I loaded a few things into the trunk it is a bit more pronounced. Even when going over a speed bump.
What I have determined from the one inch pile of receipts, all work done at the dealer theses have been replaced.
Rear trailing arm bushings replaced, form says they were cracked @ 104K
When you push down on the rear either side the shocks appear fine and there is no noise but have not been replaced as far as I can tell.
Looking for ideas and ways to troubleshoot the noise without just changing parts and would appreciate any insight...
thanks!!
thanks!!
