b16b
s80 transmission
No codes, at all
new:
wires
plugs
cap
rotor
ICM
oil change
coolant change/ fully bled
Checked:
fuel pressure
ICM ( thus the replacement, it was throwing below standard voltage on 2 pins and had 0 conductive grease on it)
The car drives and acts fine when cold (over night) , can make it the 17-20 mile drive to work with no problem, standard acceleration, everything.
When the car warms up, it will idle fine...
idle drops to 5-700 , then at cruising around 3krpm, the rpms will jump, the car will sputter/buck and then rpms will drop to 0 and the car dies.
My next thought would be the TPS through the crude method of just unplugging it while at rough idle and it normalizes to ~800-1k
Other than that I'm at a loss....
Going to replace the tps tomorrow and drive around town and see what happens
Any other thoughts as to what it might be should this not work?
I was thinking cooling system related next.
s80 transmission
No codes, at all
new:
wires
plugs
cap
rotor
ICM
oil change
Checked:
fuel pressure
