OFFICIAL DIY: Mishimoto Radiator Install - 97 Civic
Discussion in 'Engine Tech / Drivetrain DIY How-To's' started by Jay Jay, Jul 22, 2008.
  1. Jay Jay
    Jay Jay Administrator Staff Member Registered VIP Registered OG Premium 5+ Year Member 10+ Year Member
    Jan 1, 1970
    5,342
    DIY: Mishimoto half length radiator install on a 1997 Honda Civic
    Applicable Years: 92-00 Honda Civic
    Difficulty: 2 out of 5
    Estimated Time: 2hrs
    Upgrading your radiator to increase engine performance and cooling efficiency is really an easy task. And Mishimoto makes an affordable aluminum radiator to do just that and the quality is great. I finally decided to replace my Koyo radiator. It was too thick causing it to hit my turbo being forced to sit crooked, not really being secured.
    [​IMG]
    Here is a comparison of the old Koyo and the new Mishimoto. You can see the Mishimoto is a bit thinner and not quite as wide, which will fit just perfect in my engine bay.
    [​IMG]
    Mishimoto Honda Civic Radiator 1992-2000
    The half length civic radiator is a perfect upgrade for anyone looking to increase engine performance and cooling efficiency. Popular among import tuners, this half sized radiator can also be tailored towards B and D series motors in custom applications (note: Mishimoto cannot give technical or installation help on custom application installations).
    Model: MMRAD-CIV-92
    MSRP: $250.00
    Tech Specs
    Core Size: 350mm x 358mm
    Rows: 2
    Inlet: 32mm
    Outlet: 32mm
    Core Thickness: 42mm
    Tank Wall Thickness: 2mm
    Fill Neck : 31mm
    Note: This item is for Manual Transmission vehicles. For automatic applications, please purchase optional Mishimoto transmission cooler (P/N: MMTC-U)
    Purchase Includes: Mishimoto Radiator, Mishimoto 1.1Bar Rad Cap, 1 Year Warranty
    [​IMG]
    [​IMG]
    Installation:
    1. To start, jack the front of the car up using the recommended steps in your operators manual.
    2. Next remove the drain plug, draining the coolant into a drain pan. Remove the radiator cap to help the fluid flow faster.
      [​IMG]
      [​IMG]
    3. Once all of the coolant is drained you can remove the upper reservoir hose, upper radiator hose and lower radiator hose.
      [​IMG]
      [​IMG]
      [​IMG]
    4. Next unbolt, unplug and remove the radiator fan. I was using a slim fan in "pusher" mode in front of the radiator.
    5. Once everything is disconnected from the radiator, remove it.
      [​IMG]
    6. Install the new Mishimoto radiator into place. Making sure the feet seat correcting below.
      [​IMG]
    7. Mount and connect the fan. I had to switch my slim fan back to a puller since it is now back in the stock position.
      [​IMG]
    8. Reconnect the upper, lower, and reservoir hoses.Now I just need to get a new upper radiator hose since mine is to short.
      [​IMG]
    9. Fill the radiator up with 50/50 mix of coolant and distilled water.
    10. To bleed the system, allow the car warm up to operating temperature with the radiator cap off to allow air bubbles to escape. Shut the car off and refill will coolant and replace the cap.
    For more information on this product and any other Mishimoto products, please visit www.mishimoto.com
  2. JohnS.
    JohnS. BANGARANG Registered VIP Registered OG 5+ Year Member 10+ Year Member
    Jan 10, 2006
    19,339
    New York
    Great write-up :thumbs up.
    Might sound silly but do these type of radiators help at all with stock motors (particularly a D-Series)? Or would it be the same as just buying any radiator? Just curious that's all.
  3. Goodmayn
    Goodmayn New Member 5+ Year Member
    Sep 16, 2005
    157
    Baton Rouge
    Nice write up! Now replace that haggard air filter! =)
  4. Jay Jay
    Jan 1, 1970
    5,342
    Haha, nice catch. That is next on the list ;)
  5. Lonestar
    Lonestar Honda Driver 5+ Year Member 10+ Year Member
    Oct 29, 2003
    77
    Canada
    Does anyone know off the top of their head the fan size for a 6th gen? If I swapped my rad with this one, I'd like to do the fan too.
    By the way, nice write-up.
  6. 92h22eg
    92h22eg New Member Registered VIP 5+ Year Member
    Apr 26, 2008
    420
    GA
    you should be fine with a 12" fan
  7. Jay Jay
    Jan 1, 1970
    5,342
    Yup, I'm using a 12" slim fan on mine.
  8. CivicMafia
    CivicMafia New Member 5+ Year Member
    Jan 24, 2009
    241
    Panama City Florida
    Actually, im 99.9% sure you want to fill it up cold, or while its running, Dont let it warm up. Unless you really feel like taking a risk of replacing your block
  9. Alberto521
    Alberto521 Just call me Alberto Registered VIP 5+ Year Member
    Sep 23, 2008
    952
    Chicago, IL
    Great write up, but as Amej8 said....
    "Might sound silly but do these type of radiators help at all with stock motors (particularly a D-Series)? Or would it be the same as just buying any radiator? Just curious that's all."
    Because i got a DX, and i think my radiator is going bad...
  10. jon julian
    jon julian New Member Registered VIP 5+ Year Member
    Feb 19, 2006
    779
    the Redlight District
    i just installed my fullsize mushi in my DC2....damn it looks blingin...makes bay look more appealing...
    since im not running a slim fan, i had to trim a little bit plastic off my stock fan so it wouldnt melt on my header and a simple 3 or 4mm notch for the upper rad hose...i did it with a knife in couple min, nothing to sweat though..... only thing was once i started the car it started pissin a lil stream out of the fluid release nut inbetween the rubber gasket....but nothing that lil teflon tape couldnt fix.
    so it works the way it should and fits like a glove. im happy with it.
  11. NFR_AP2
    NFR_AP2 New Member Registered VIP Registered OG 5+ Year Member
    Sep 12, 2006
    8,405
    New Jersey
    just installed this rad in my EK a few days ago...fits perfect. no complaints on my end!
  12. mattman3
    mattman3 got rice? 5+ Year Member
    Oct 14, 2009
    88
    new jersey
    can i take my stock radiator fan off my stock radiator and put it on the mishimoto one or do i have to get a different fan?
  13. Jay Jay
    Jan 1, 1970
    5,342
    The stock fan will bolt up to the Mishimoto radiator. I assume you have a 92-00 civic? I also just pm'd you a price on a radiator if you are looking to buy one.
    - Justin
  14. originalem1
    originalem1 em1
    Feb 19, 2010
    28
    south Florida
    I own a 2000 civic si, I wanna replace the stock rad with a mishimoto would the stock fan fit or would I have to get a slimfan
  15. Jay Jay
    Jan 1, 1970
    5,342
    The stock fan will fit. If you want a price on the radiator let me know.
  16. Hecz
    Hecz New Member Registered VIP Registered OG 5+ Year Member 10+ Year Member
    Aug 10, 2003
    13,646
    Chicago, IL - USA
    How's the fitment between the top of the radiator and the upper radiator support? My Koyo (just like what JayJay replaced in his write up) doesn't clear the upper rad support, i had to push the radiator down as far as i could, then wedged it under neither the upper rad support.
  17. originalem1
    originalem1 em1
    Feb 19, 2010
    28
    south Florida
    so it fits the oem hoses then?
  18. Mishimoto
    Mishimoto Product Manufacturer 5+ Year Member
    Apr 3, 2009
    175
    Wilmington, DE
    ^^ Yes, you may use your OEM hoses.
  19. imfromdade15
    imfromdade15 New Member 5+ Year Member
    Feb 10, 2010
    49
    Miami, FL
    does this radiator work for a automatic transmission, summer is coming and it gets really hot and humid in miami and would like my engine to stay cool.
  20. Mishimoto
    Apr 3, 2009
    175
    Wilmington, DE
    Yes, the radiator will work with your Automatic transmission, however, you would be required to run a transmission cooler. We actually offer those, too.
    Let me know if you have any additional questions!
Loading...
: official diy
Share This Page
