mrshlz
hey all, was needing some help in figuring out why only one drl light (passenger side) works after installing led bulbs in my 05 civic. I've also tried to use a decoder and checked the fuses and bulbs and also replaced the 50watt led with a 100 watt with no result. Could it be a relay issue? Should i get a load resistor instead? The drls both work when high beams are on and low beams are fine its just when the drls are on that only the passenger lights up. Any advice would be appreciated, Thanks.
