Overheating while idling
Discussion in '7th Generation Honda Civic (2001-2005)' started by meg828, May 18, 2017.
  1. meg828
    meg828 New Member
    Nov 7, 2016
    11
    Smryna
    I recently had the radiator replaced. I flushed out the coolant just to be sure there were no air bubbles. After an hour of idling the fans did not kick on. They would turn on when I turned on the a/c but, even then the car still overheated. What could be the problem?
  2. cammac1336
    cammac1336 New Member
    May 19, 2017
    5
    US
    What year and model car do you have?
    Sent from my HTC One_M8 using Tapatalk
  3. meg828
    meg828 New Member
    Nov 7, 2016
    11
    Smryna
    2003 Honda civic
  4. boofoo
    boofoo Respected Registered VIP
    Oct 15, 2016
    2,046
    United States
    Describe the bleed procedure
  5. meg828
    meg828 New Member
    Nov 7, 2016
    11
    Smryna
    Took off radiator cap. Let car run when antifreeze bubbled out put a bit more in over the period of an hour.
  6. boofoo
    Oct 15, 2016
    2,046
    United States
    The heater valve must be wide open (heater dial to max) when bleeding the cooling system.
  7. meg828
    meg828 New Member
    Nov 7, 2016
    11
    Smryna
    It did get to the max.
  8. cammac1336
    May 19, 2017
    5
    US
    Are you sure the radiator fans are working, not just the Ac fan
  9. meg828
    meg828 New Member
    Nov 7, 2016
    11
    Smryna
    The radiator fans will not kick on unless I turn on the a/c and still even then the car still overheats.
  10. boofoo
    Oct 15, 2016
    2,046
    United States
    Temp on cluster gauge?
    Rent a block tester kit.
  11. meg828
    meg828 New Member
    Nov 7, 2016
    11
    Smryna
    Yes. Can I find that at any auto parts? How is the kit going to help?
  12. boofoo
    Oct 15, 2016
    2,046
    United States
    The block tester is one of the best ways to determine whether the head gasket is blown.
    However, it's hard to know with certainty based on the information and lack of information in your posts, but you may not have properly bled the cooling system.
  13. meg828
    meg828 New Member
    Nov 7, 2016
    11
    Smryna
    Update the car is not overheating while idling but the fans still won't kick on until the a/c is on.
  14. bradfoulks
    bradfoulks New Member
    May 21, 2017
    4
    US
    I'm actually having the same issue. With my fans.
    Sent from my SAMSUNG-SM-J120A using Tapatalk
  15. meg828
    meg828 New Member
    Nov 7, 2016
    11
    Smryna
    So I'm guessing the fan need replacing?
  16. cammac1336
    May 19, 2017
    5
    US
    Are you sure the radiator fans are working, not just the a/c condenser fan when you turn on the a/c
  17. meg828
    meg828 New Member
    Nov 7, 2016
    11
    Smryna
    I'm honestly not sure. I'm getting it checked out next weekend. Hopefully it's something small
  18. cammac1336
    May 19, 2017
    5
    US
    It could be as simple as a bad connection. Or just a fan to replace.
  19. Otto85
    Otto85 New Member
    Mar 26, 2016
    102
    neverland
    Did you unplug the fan switch and jump the connector or did you bypass that test
    Sent from my LG-LS997 using Tapatalk
  20. meg828
    meg828 New Member
    Nov 7, 2016
    11
    Smryna
    I don't know how to do that test.
Loading...
Share This Page
