mikelangleo984
Been working on my sisters 2005 Civic DX since it keeps overheating. The weird part about it is that it stays at normal operating temperatures at idle but when i take it for a test drive a few miles out it starts to heat up. I brought it back home and left it running to check if fans were working, which they were, the car then returned to normal temp after a few moments. I have tested and replaced the engine temp sensor and the fan switch. Changed the thermostat and did a radiator bleeding for air. Havent checked anything with timing belt or water pump but i figure they are ok since the car cools down at idle. Any help is appreciated and thank you.
