Overheating
em1_coupe
My 1997 civic is overheating. Fan is good, the sensor is good and fuse is also good. Had problems with wiring fixed that, and it was turning on and but out of nowhere it started to overheat
em1_coupe
Start with the fundamentals. Check the coolant levels in both the radiator and reservoir.
I did the a coolant flush, but they fan won't turn on. It brand new, new sensor and fuse and also fix some one the wiring problem that it had
codyruffgsd
Have you checked your thermostat? It could be bad and not opening so it can't allow coolant to get into the motor
Sent from my SM-J327P using Tapatalk
