Good info.oil is always needed. you would damage the engine without any oil and your test wouldn't give accurate results
Really depends on your plan/budget. I usually buy a motor with the thought that it's going to have shat internals anyway, and plan to rebuild it. That being said, if you want a direct drop-in, yeah. It's a bit risky. If you don't have the funds to replace piston rings, do a valve job etc., I'd ask a LOT of questions and ask for any and all recent receipts for oil changes etc.Good info.
Turns out he's already removed the tranny! I guess we'd have to install the tranny, add engine oil, add tranny oil, brace engine, test the engine, drain engine oil, drain tranny oil, remove the tranny. Ick. And draining the fluids might be tough since we have neither stand nor hoist.
The engine has less than 120k and seller claims it ran great before he decided to upgrade. It's a great price too. How stupid would it be to buy without testing?
Thanks.Really depends on your plan/budget. I usually buy a motor with the thought that it's going to have shat internals anyway, and plan to rebuild it. That being said, if you want a direct drop-in, yeah. It's a bit risky. If you don't have the funds to replace piston rings, do a valve job etc., I'd ask a LOT of questions and ask for any and all recent receipts for oil changes etc.
The issue is that the starter motor is attached to the transmission housing. So we're both assuming that the only way to use the starter motor is to bolt the transmission back on. I just want to verify it's OK to crank the engine with the transmission dry. Assuming yes since it will be in neutral, but just want to verify.you're just compression testing the engine. you dont need the transmission hooked up since it would be free floating in neutral
Boston area.Where in mass are you.
Good to know! I'll look into this. How likely is it that the readings will be inaccurate due to the engine being cold? (I know it's best to do a compression test when the engine is at operating temperature to avoid inaccurate readings.)Also there are YouTube videos to this even if you don't have a tranny on you could still do it my turning the crankshaft but you have to be strong.
Thanks. Honda's service manual says nominal is 185psi, minimum is 135psi, and maximum variation should be less than 28psi.The tranny woot even move and look for consistency not just high numbers. My ls was 200-205psi over all four , my gsr 225psi and my b16 215 over all of them. If it's off by 8-10% be careful
