I havent been posting pics of this project but i figured i would start so heres hows it coming out so far. And i will keep updating on the progress. But heres how it is.
you spin those rods afterwards to make sure they are still balanced? or measure them to make sure they are still the same weight as the other ones?Honda Importz89 said:And im polishing the rods, which means i was removing the casting line from the rod so its strong. The casting is the first part to crack in rods, so with it removed and flush with the rest of the rod its stronger.
So any more questions?
X2ryan89crx said:you spin those rods afterwards to make sure they are still balanced? or measure them to make sure they are still the same weight as the other ones?
those 2 factors are 10x more detrimental to a motor than the casting marks will ever be
very very true you are right. I have not balanced them yet which i should and will do on tuesday. Thanks for that inforyan89crx said:you spin those rods afterwards to make sure they are still balanced? or measure them to make sure they are still the same weight as the other ones?
