Question for anyone to take a shot at.
Dont_Tri
So my friend wanted a Si like mine after he saw and drove mine. He found one that is completely stock and still loves the way it rides and feels. However, he went to check the oil yesterday in his garage and he noticed a slight smell of fuel on his oil? Any ideas to what this may be fellas?
neoc03
I CRAVE CORNERS
Is he sure it's coming from the oil and not it being couped up in the garage?
Dont_Tri
Nope he said it's the Oil he saved the bounty paper towel he checked the oil with and gave it to me to smell the oil and I smelt it like a slight fuel smell also. I have no idea.
Billy.
Has returned ;-)
ComPrEsSioN cHecK TImE
Dont_Tri
yep....may need some piston rings
The car doesn't smoke at all just a little black smoke when he get's on it at high rpms and I have seen alot of civic and acura shot the black smoke when they get on it at high rpms
Billy.
Has returned ;-)
that's what my b16 did about 5k miles before i had to do a block swap from burnout piston rings
just do the compression check and let us know what it turns up
Dont_Tri
Okay like if I knew how to do that lol and he just started in the Honda world. How would we do a compression check A and B I heard of a wet compression check with a teaspoon of oil in the chamber and turn the motor.
I have an idea but let's see if I'm right
Dry comp test
1. disconnect all wires to the plugs.
2. remove all plugs
3. screw in compression check device
4. turn ignition and read dial for messure of compression in that cylinder.
Wet comp test repeat steps 1-4 but before you turn ignition insert a teaspoon of motor oil in the chamber?
I could be wrong but this is what this forum is for advice and suggestions.
JCCLARK
The Painter
Sounds like leaking injectors.
Is his car hard to start when still hot but set for several minutes?
That wouldl be 1 sympton.
Hook up a fuel pressure gage and watch it after the engine is shut off,
it should hold pressure.
It's not likely to get gas in the oil while it's running,
even with low compression, the fuel would be burned.
Unless you had so much fuel dumped in it couldn't burn it all,
if that were the case it would be putting out clouds of black smoke.:cool:
Dont_Tri
Yeah clouds of black smoke when he get's up there like 6000-7000rpm. Or if he floors it you see black smoke. So it could be his injectors ?
toneekay
Rubbin on yo booty
i get black smoke at 3k rpm... VTEC BABY WOOO WOOOO WEEEEEDDDD WOOOOOO DANKKKKK WEEEEEDDDDD GREEEEEEEEEN WEEEEEEEEDDD WOOOOO PEW PEW!!!
