Riick
Removing my engine (D15B7 in a 93 DX) and have questions...
1) Do I need that special ball joint tool to pull the lower control arm off the ball joint? (Service manual says its needed but I also heard I can pry the lower control arm downwards while hammering it where it goes around the ball joint.) What have people tried? If I need the special tool where would I get it?
2) For removing the spindle bolt, I heard the hub can be anchored by sticking a screwdriver in the rotor so it catches against the caliper. But doesn't this damage the rotor or caliper (or screwdriver)? Is there a better way?
3) Going to need to pull the flywheel too- does it need a torx socket or something? Anyone know what size?
4) What other tools will I need? All I have is the following:
- 3/8" drive 6-pt. sockets + ratchet + 6" extension + 8" t-handle + 18" cheater bar,
- 1/2" drive impact sockets + 18" t-handle + adaptor for using 3/8 ratchet.
- 2 lb hammer.
- pb blaster
- propane torch
- talent for getting in over my head
- 2 lb hammer.
- pb blaster
- propane torch
