CivicEx'00
Hello, I recently installed a touchscreen headunit in my 2000 EX, but ever since then I've had a faint electrical him coming from the speakers. I've done some reading and I'm guessing it's a grounding problem, but I'm not quite sure how to fix it.
Three hints:
-the hum doesn't change with volume
-it doesn't change with RPMs, it's present in radio mode too, so it's not my aux cord
My questions:
There are some metal bracket plates behind the radio for structure, should I try grounding to that instead of using the harness ground?
Where is the harness ground located so I can maybe hit it with a wire brush and WD-40?
Thanks for any help
Sent from my SM-G920V using Tapatalk
Three hints:
My questions:
Thanks for any help
