steve.21
Hey everyone. My car has been having misfire only on startup. It does not matter if the engine is warm or cold. When I start up the car one of the following things will happen
Starts perfectly fine no problems (20% of the time)
Starts up and has a rough idle for about 30 sec then the down cylinder/s start to work throwing no codes (40%)
Starts up and has a rough idle for about 30 sec then the down cylinder/s start to work throwing codes cylinder 1 and/or 2, 4.. Never 3 for some reason. With a random misfire code... Forgot the number (20%)
Starts up and throws codes(same codes) and stays until I hit the gas and the rpm's go above 1500. Then runs fine. (15%)
Takes forever to start followed by only one cylinder firing... You can hear and feel it. Then stalls throwing no codes. (5%)
Only mod I have is a new short ram(problem existed before I got it)
I have replaced the plugs, wires, distributer cap rotor.
Cleaned the iacv, distributer cap, throttle body.
The inside of the dizzy cap looks fine and the spark plugs are dry.
When I got my car smogged my ignition timing says 11btdc. Don't know what that means. Could the problem be in the fuel injectors, tps, or any other sensor thing. I don't have access to a engine hoist or anything fancy.
Any help will be greatly appreciated and I will try to respond as fast as possible to anyone.
Edit: it is a 97 lx auto transmission.
