Hello.....
The radiator fluid in my 2001 Civic Lx appears to be a dark green color. I bought some Honda brand radiator fluid at a Honda dealer and it looks like it is blue colored. I was going to add a little to the expansion tank as it is right on the bottom mark when the engine is cold. I don't know if I should add the blue colored Honda fluid to what is in the expansion tank due to the different colors. I had the timing belt and water pump changed at a Honda dealership last year and a radiator fluid change was part of the job. What I can't understand is why they would use a different color fluid than the Honda brand.
Do you think it would be O.K. to add the blue Honda 50/50 mix to the fluid that is in the expansion tank, which is a dark green??
Thanks......
Thanks......
