especko said:
any screw driver will work, i believe its a phillips one for the screws inside the fender, a flathead will help with the plastic clips, and u will need a 10mm socket to take out the 2 bolts underneath the car
That's correct. On the passenger side underneath the front there is also a phillips tip screw connecting your fender liner to the bumper. Keeps my CAI alot drier.
The headlights have two screws on top, don't forget to remove the black metal piece underneath them too (two screws). There is also s screw on each side of each headlight.
So, in summary:
Headlights - 2 on top, 2 on bottom (to remove black metal piece), 1 on either side.
Bumper - 1 in each fender well, 1 on bottom front passenger's side, 2 (10mm) in the middle underside, 7 total clips on top which can easily be popped up with a flat-head screw driver and then removed by hand.
