98ej7HX
Poor College Kid
So i'm trying to install my coilovers, and the front went flawlessly, and took about 20 minutes. However, all of the bolts that go into the rear LCAs are stuck, except the ones connecting the shock fork to the lca. I tried using a prybar to pry down the hub assembly as much as possible to see if the shock would come out, but there isn't enough clearnace. I was wondering if i compressed the spring while the assembly was still in the car if that would make it easier for me to just pull the whole thing out? I have pretty much given all hope of being able to disconnect the lca from the subframe (due to stripped bolts from me trying) Or the hub assmebly(not sure what it's called) so I am trying to think of ways to get the shock out. Next step I was thinking would be to heat the shock up with a torch, bend the forks up so that the shock would just slide out to the side..any help or ideas would be appreciated!
