short shifter
martn53
do 88-89 corners fit 90-91 ?
anyone know any diy installs for short shifters?
i have no clue how to put one in
any help greatly appreciated thanks=)
19ef90
i dont see why they wouldent fit..
its a 4th gen still.
JDMefHATCH7
idk if they do or not...what i know is that the corner lenses from 88-89 have hole in the 90-91 dont they have a lil clips to hold them from the back...you can try....
Kay@NHT
the corners are diffrent some have 2 screws in the side and some have a mounting tab at the top of the light
depends on what u have
short shifter DIY i thing D-series has a good one
Good luck
jdmd16ej8
Im So Daily ED
swappin shifters is real easy, just drop the linkage and pull it out the whole car, then have a buddy with some pliers or vice grips hold the flat screws where the shifter is and you rachet the bolt off should come off, and putting it back is just reverese
apekd
-----Distracted you, huh?
yes its the same. its the same for 88-00 and 94-01 integra's. same shifter. just drop the linkage by the 2 12mm bolts, and then the 12mm bolt that holds it to the bottom linkage, and 2 10mm for the 2 bolts that hold the ball in place,.
jdmd16ej8
Im So Daily ED
just have a friend hold a pair of vice grips on those, then you just rachet the bolts off, be careful not to snap it though, gl man
