I've ridden in a car with skunk2 suspension and I wasn't impressed. I'll post some pictures of mine later if you want.Mhm so FF sounds pretty good to go low, on some other forum people are recomending FF also .. Some say they ride a little better than Skunk2
Softer springs by themselves won't get your static ride height lower, they very likely wouldn't change the ride height even the slightest bit. They will only cause problems if they are too soft by allowing your UCA's to hit the shock tower and your tires to rub the insides of the fenders. You'll need to know what spring rate to go with if you want shorter springs. Too short and too soft can cause coil binding. Not to mention at some point, if you're not already breaking through your shock towers, you have no more suspension travel at all making your suspension useless. Not to mention one hell of a sh*tty ride.If you wanna slam your car, FF or Buddy Club could do that. I have skunk2 pro s version 2s on mine.
Tires are 205/50. The fronts still has 0.40" to go. The rear still has 0.75" to go. If you wanna go lower, get softer springs or shorter springs. I didn't keep it at this height though. I just did this for shiz and giggles. The ride isn't bad in my opinion.
Yeah that would be great if you could post some pics please ...I've ridden in a car with skunk2 suspension and I wasn't impressed. I'll post some pictures of mine later if you want.
Mhm but your car looks lower than how i have mine, which is good!!If you wanna slam your car, FF or Buddy Club could do that. I have skunk2 pro s version 2s on mine.
I want some of whatever you're smoking.I have Function and Form Type 1s on mine. I ride pretty slammed as is and I still have leftover threads. I loveeee them and they ride like stock.
