Edonew
Solved: It was the Fuel Cut Off Switch.
Hi! Having some issues with my car.
A Honda Civic 2008 2.2 Diesel. The problem is that it wont start. It cranks with jump cables but slowly drains when trying to start and dosent not turn over. Also the OBD Port do not connect with any OBD Scanner. This is what i have tried to fix it.
Check all fuses and relays. Battery at 14 V when trying to start. Key is recognized. Disconnected battery pole tried reset the ECU.
It all started when the DPF light came on and said Check system. Opened upp DPF Sensor and cleaned the pipes with DPF cleaner. Also added DPF cleaner in the tank. Then it died at first start then worked. The light never went away but it came out of limb mode.
- If anyone have any suggestions what the problem can be with the car? Im thinking Fuelpump do think it is a mechanical Fuelpump, or maybe a bad ECU.
Thanks in advance.
Thanks in advance.
