ShinsenTuner
CC's Youngest OG
Hello all, I come to you with some issues I need help with...
My buddy has a 1998 Civic DX Hatch that originally had a JDM B18C in it. It was taken out for a rebuild and a stock 1996-1998 Civic D16Y8 motor was dropped in. The engine harness, ECU, everything, was from the Civic EX donor car. We dropped it in, and ran into some issues. The car starts and runs, it just has problems.
1. The idle is fine when initially starting it. After driving however, the idle fluctuates between 2500-3000RPM and doesn't return to the 700-ish-RPM it's supposed to be. I believe this might be an issue based from a vacuum leak, which might be caused by the hoses on the intake manifold being placed incorrectly or something. On the D16y8 there is a black plastic hose outlet inbetween the fuel rail and the intake manifold, there are two outlets and I am unsure of what to do with it. The original black-box hose on the DX shell was replaced with a really long one for the B18C, but there seems to be two outlets on the intake manifold that have nowhere to be connected... I looked in the Helm's manual and couldn't find anything.
2. The car is throwing a code 15 for allegedly running lean and/or having a distributor issue. Should replacing the distributor with another one help? Or is there another underlying issue...
Also, completely irrelevant to the motor... does anyone have a diagram of where you bleed the rear brake drums with? We can't figure it out. Thanks all...
