nailguy
I have a Honda civic ex 2004 and the speedometer and odometer has stopped working and I have replace both sensors the vss and the other speed sensor, along with doing the cluster check it shows good. what else could be causing these two not to be working. during the test the needles move all the way to max and return as they should and then 1 beep when I push button and it does it again and it shows all 88888 no errors.
