srs and engine diagnostic test are 2 totally different things. you can take it to the honda dealership to have them do it but it costs a bitFLAteam said:try taking it to a place like autozone, pep boys, advance auto parts...or whatever you have out in CA. They should run a diagnostic for free.
ashtrey634 said:^
he beat me to it
well, not so common .... not in europe only when people unplug the wrong things so hence the question, maybe he didn't reconnect somthing properly and it loosened ...got traction said:its sooooooo common for 6th gen to have this happen for no reason
chartinael said:well, what does out of nowhere mean? in general there are two reasons or better three : passenger airbag, steering wheel airbag, srs unit defective.
also, possible causes: cable reel broke, any yellow plug undone. So first off, check all you yellow plugs, did you unplugg any connector, is anyone of them broke, loose or antyhing lke that.
if all seems all right and you haven't done anything else like take out an airbag or remove steering wheel, try the resetting routine. it should work, if it comes back on however, then more differenitated diagnostics is in order.
