start up misfire
Teck95
Hi i have a 95 civic dx with a short ram intake and a catback the car just recently started misfiring upon start up doesnt do it all the time and after running for a while if i shut it off and let it sit about 10 mins it misfires when i start it up the cap and rotor are a year old as well as the fuel filter. i just replaced the plugs and wires and it still does it. i do have some oil leakage onto the outside of the plugs iv replaced the valve cover gasket 3 times and it still leaks. also every couple weeks it overheat because im loosing coolant some where and help at all would be great im completely stumped and dont have a load of cash to try and correct this problem. also the car has 221k on it
2slo4u
wait4me
Are you changing out the spark plug hole rings when you change the valve cover gasket?
Any CEL codes?
You are losing coolant. Does the engine also overheat? White smoke in exhaust? Oil in cooling system? Coolant in oil? You may want to check for a blown head gasket by doing cylinder compression and leak down tests.
Is the white smoke at start up just normal condensation in cold weather or is it more than that?
Teck95
even when the cars at running temp it still has a lil smoke i notice quite a bit of water in the tail pipe though
As you are losing coolant, pressure test the cooling system in an attempt to locate the leak. If none is found, do a cylinder leak down test to see whether cylinder compression is lost into the cooling system (=blown head gasket).
deevibez17
1999 Civic Hx
story of my life, i tried diagnosing my overheating prob. until i blown a head gasket. now i jus wanna ride it out until i save enough for a swap.
SnoFox4
Most Boring Car
Don't jump to conclusions, do a comp test. It could be a burnt valve, head gasket, piston rings, scored piston lining, valves adjusted incorrectly (so that they're held open too long), it also could be ignition related.. have you tested the spark plug for each cylinder? Check to make sure all of your injectors are opening too, one of them could be getting old and gummed up.
Just check the four things needed for combustion: air, fuel, ignition, exhaust.
Teck95
still havent figured it out starting to hbave quite a bit of white smoke when i start up
Teck95
so my white smoke is getting worse im going through a half gallon on antifreeze a week so im pretty sure its the head gasket iv been searching diffrent had gasket kits and reach my new dilema graphite head gasket or multi layers metal any suggestions please and thanks
92EH9
flat black rat
head gasket is shot. i always use the triple layered metal gasket. its not a bad job if you knw what u are doing. i would recommend changing the timing belt and water pump while u have it all torn down.
Teck95
well since im not miling the head i figured maybe the graphite would be better
