You are going to have to run the appropriate wires to the appropriate pins on the ECU...
But to more generally answer your questions, I would pull the harness from the CRX and lengthen wires as needed for simplicity.
You will require the wire and ECU for it to run, you may have to run a few miscellaneous lines/wires for the cluster etc...
