Full Size Shots
http://the-perfect-exposure.blogspot.com/2009/02/m2-motoring-bmw-m3-w-vf-engineering.html
2006 BMW M3
OEM Specifications
Exterior Color: Alpine White
Interior Color: Imola Red Leather
Transmission: 6 Speed Manual
Engine: S54 3.2L I6
Modifications
Exterior
* OEM Euro M3 Front bumper
* Front reflectors deleted
* Ac scnitzer front lip
* Hamann brake ducts custom molded to front bumper
* Seibon Carbon fiber hood
* CF Hamann GTR sideskirts
* Seibon Carbon fiber trunk
* Custom rear diffuser
* Depo Smoked corner lenses
* Black matte front kidney grilles
* Black matte side grilles
Interior
* Recaro Pole Position bucket seats black leather/grey suede
* VAC Floor mounts
* Recaro sliders
* Recaro aluminem side mounts
* Crow 4-point racing harness - red
* Hamann aluminum shift knob
* LeatherZ Imola red w/ black stitch shift boot
* LeatherZ Imola red w/black stitch emergency brake boot
* Bimmian aluminum e-brake handle
* Bimmian aluminum pedal set incl. dead pedal
* Defi BF series boost gauge
* Defi BF series oil pressure gauge
* Innovate Digital Wideband A/F ratio gauge
* Defi control module
* Full custom bolt-on 4pt. roll cage with removable harness bar by Oink Fabrications
* Roll cage custom powder-coated white.
Engine
* VF-Engineering Stage 2 Supercharger system
* GIAC custom tuned stage 2 software
* Top speed governor removed
* Vortech V2 Super Quite SC trim polished supercharger
* Replacement OEM serpentine belt
* Replacement serpentine belt tensioner
* Replacement 8.0-8.5 psi supercharger pulley
* Replacement chargecooler manifold
* Bosch water pump with VF water reservoir system
* VF- CNC machined 6061 aluminum bracket system
* OEM BMW idler pullies
* Replacement fuel pressure regulator
* Stage2/3 OEM High flow spray pattern matched fuel injectors
* VF- Custom molded polypropylene ducting
* VF- Custom tuned supercharger intake
* High flow overrun bypass valve system
* Custom crank case ventilation system
* 4 ply silicon couplers with OEM screw clamps
* VF - CNC oil fittings with high pressure OEM oil lines
* MAF upgrade conversion
* K&N induction filter with cold air intake
* JIC Cross Competition quad-tip SUS exhaust
* JIC Cross Competition section 2 SUS midpipe
* Ki’s Racing Titanium section 1 pipes
* Custom Rogue aluminum Oil cap with senders
* VRS custom black cf engine cover with silver cf center insert
Wheels/Tires/Suspension
* Volk CE28N Time attack 19×8.5, 19×10.5
* Hankook Ventus S1 Evo Tires 245/35-19, 285/30-19
* JIC Cross Competition coilovers
* JIC Cross camber plates
Brakes
* JBT front and rear big brake kit
* JBT 6 Piston front calipers
* JBT 2-piece 355mm slotted rotors front
* JBT 4 Piston rear calipers
* JBT 2-piece 355mm slotted rotors rear
* Stainless Steel brake lines
* Hawk brake pads
Audio
* Memphis Audio M-Class 5.25 components
* Memphis Audio M-Class 6.5 components
* Memphis audio components
* 2 12 Memphis Audio M-Class subwoofers
* 2 Memphis Audio M-Class amplifiers
* Custom Fiberglass subwoofer enclosure painted alpine white, wrapped in Imola red leather
* Custom Plexi-glass Amp rack wrapped in imola red leather
* White LED lights to illuminate amp rack and subs
* All gray trunk lining dyed blackTrunk Wrapped in red leather
* Memphis Car Audio Tweeters with cross-over
* Complete Audio system to be done by Autofashion USA
