Both methanol and ethanol burn at lower temperatures than gasoline, and both are more volatile,Using methanol as a fuel in spark ignition engines can offer an increased thermal efficiency and increased power output (as compared to gasoline) due to its high octane rating (114[3]) and high heat of vaporisation.The improvement consists of using dual-fuel direct-injection of pure alcohol (or the azeotrope or E85) and gasoline, in any ratio up to 100% of either, in a turbocharged, high compression-ratio, small-displacement engine having performance similar to an engine having twice the displacement. Each fuel is carried separately, with a much smaller tank for alcohol. The high-compression (which increases efficiency) engine will run on ordinary gasoline under low-power cruise conditions. Alcohol is directly injected into the cylinders (and the gasoline injection simultaneously reduced) only when necessary to suppress ‘knock’ such as when significantly accelerating. Direct cylinder injection raises the already high octane rating of ethanol up to an effective 130. The calculated over-all reduction of gasoline use and CO2 emission is 30%. The consumer cost payback time shows a 4:1 improvement over turbo-diesel and a 5:1 improvement over hybrid. In addition, the problems of water absorption into pre-mixed gasoline (causing phase separation), supply issues of multiple mix ratios and cold-weather starting are avoided.
Ethanol's higher octane rating allows an increase of an engine's compression ratio for increased thermal efficiency.[
i hope that helps
