Okay, since my clutch was slipping, i replaced it wth a new ACT clutch and pressure plate, new throw bearing...After installation, I test it around the block and seems fine.
Turned off and start back up and it wouldn't go in gear. I did bleed the CMS. (new clutch master cylinder)
Then I notice that if i step on clutch about half way, it would go in gear..but if i step on clutch all the way to the fire wall, it wouldn't go in gear unless i step half way.
Any problem to solve this? I hate stepping on clutch half way. doesn't seem normal. any help is appreciated. thanks!
