Tuning B16
civic98turbo
I'm back ....
a couple quick questions...
i'm planning on getting my car tuned....cause i need it...
Jdm B16a obd1
I have a :
short ram intake
test pipe
full exhaust
VAFC 1
Fuel Pressure Regulator
CTR Cams
coming right now:
Skunk 2 Pro Series I/M
4-1 Header
me never having to get a car dyno tuned..@ 175/hr...how long do you think it will take to tune...i'm not scared to spend the $$ to get it tuned...i just don't want a $600 bill for nothing serious...
i've heard with my setup...they will mess with the VAFC, and probly my timing a little bit...
i'm just curious....this is completely new to me..
thanks
Steven.
Formally Green 91
tuning usually takes aroudn 3hrs.
instead of the hack, get a chipped ECU and run crome
Handlebars
None Taken.
tuning an n/a setup on a vafc wont net you that much hp gain, nor will it take anywhere near 3 hours. it usually takes an hour or so on a boosted setup to get fuel right, the rest is ignition. you cant mess with ignition with a vafc, and fuel is pretty straightforward n/a, so i dont expect it to take more than 1.5 hours, and thats only if the tuner is really thorough.
ryan89crx
Spoolin single cam!
run a stock ecu. the gains from tuning wont justify the pricetag.
civic98turbo
I'm back ....
i have a P72 ecu that i'm running...how will they tune it when it isn't chipped...or is my setup even worth a chip?
i figured they would just advance the timing about 2 degrees...or somethin to that effect?
civic98turbo
I'm back ....
i was leaning towards that option anyway....so if i dyno tune it without the vafc....they will do?....like i said...stupid ?....i'm just new to dyno tuning
ryan89crx
Spoolin single cam!
without an AFC or a chipped ECU, there is no tuning possible
Steven.
Formally Green 91
hes saying you dont need a tune. run the right ECU.
dank24
yea, I dont think u need a tune either
Silver Bullet
6 spd = titis
get a turbo than tune
but i dont think u need a tune just get the right ecu
slowcivic E G
bla bla bla
i know someone who got a obd1 b16a street tuned on chrome and it made a noticable difference. 1/4 time got better and it ran better, only cost him 250 i think.
Shiznit
Stickin it to the Man
i think youll make good power with a tune.
93turbo16
Jdm B16a obd1
I have a :
short ram intake
test pipe
full exhaust
VAFC 1
CTR Cams
coming right now:
4-1 Header
thanks
Cams are a good reason to get the car tuned. I would recommend getting that ecu chipped and finding a local tuner who can hook you up. If you want the best bang for your buck, get some cam gears and then take it to the dyno.
kyle10182
NA is Best
the cams would be the only reason i'd spend money to tune that car.... you wont notice a difference over a basemap with just those other things....
civic98turbo
I'm back ....
the cams are the only reason i am going to get the tune....i got the intake manifold on....definetly bumped up on the butt dyno...it just keeps pulling and pulling ....the header is coming on tuesday....i was also considering getting some adj. cam gears to get the most out of the cams....mine as well...
slowEGG
tuning would be pointless IMO, just run a chipped p28 or p30 and call it a day.
the only reason i would tune is if you have internal work done or head work, bottom end, FI, ITB
then again if you tune then that means you will be making the most out of the car, getting to know your power bands and what not. and not running rich or lean
silver booolet
just get the thing tuned!! here in hawaii to get your car tuned run about 250 an hour.. i would tune it just to get it running right
Steven.
Formally Green 91
your post made no sense to me:???:
LOL
if your going to chip the ECU, what maps will be run?!
if your going for a chipped ECU, then get it tuned.
