which is the best program to use? i was also thinking of just getting a basemap off of turboedit think it will be fine?
How do you post em up, I have a few also?>>GreenGreen 91 said:you know we have a bin directory heere on cc right?
http://www.clubcivic.com/tuner/bins/
you still need a dyno and wideband to tune it correctly, you can run a base map but dont f**k with the seetings to much with out a wideband or you coud blow your motor. i can create a base map for boost.
you need this to actually burn thebin to the chip
http://cgi.ebay.com/AT29C256-Dual-Power-Willem-Universal-EPROM-Programmer_W0QQitemZ300007814649QQihZ020QQcategoryZ4661QQtcZphotoQQrdZ1QQcmdZViewItem
you need a socketed ECU and chips
http://www.moates.net/
its really complicated at first, it still is for me. but just do minor alterations to the maps, oh and on turboedit on the IGN maps, when you ADD to the blocks its advanceing teh timing, only add like +.50 at a time to test them. besure your up at where WOT would be, like -3
and besure you have Dual maps on, i leave it on even on NA setup.
whats your setup goign to be ill work on a BASE map
