Last week I took my hatch into get the smog test done. I changed out the entire bolt on stuff back to stock. I did a major tune-up oil change egr valve o2 sensor timing plugs with wires. I failed my co part of the test @ the 15 mph part of the test.
The tec. said that I am running to rich and my cat is not getting hot enough. RonJ sent me a thread that I might have a problem with my temp. (Thanks Ron) checked that all out everything was good except my radiator fan was not working. Changed that out now temp is fine. I have been running locus fuel injector cleaner and the car is running great.
Drove from work yesterday and went direct to the smog test only place. Got right in and tested the car again and it failed even worse. This time the 15 and 25 mph test failed the tec. said that I am still running to rich. Is there any way to lean the mix down? That is what the o2 sensor is for right? Do ca cars run two cat's one in the front by the radiator and one in the middle of the car? I look and there seems to be one there but it does not look like any cat that I have ever seen. The front cat is new and I can change out the back cat if that is what it is.
