Just get you a small LEFT HAND drill bit. Smaller then the bolt diameter.........put your drill in reverse and slowly drill it. A left hand drill bit acts as an easy out. And make sure your drill is in REVERSE or all you will do is burn up the tip of the bit. After the bit gets in the bolt it should start backing itself out. I have broke 2 VC bolts and both times thats what i had to do
