Rich F
My 91 Civic was stolen and the lock pick they used got stuck so they did some disabling at the ignition. Only 4 wires can be located that are loose. My car latter developed problems but I can't recover the trouble codes. Key first on and the engine light comes on for a few seconds but latter if I run the motor until hot it shuts down and can't be restarted for hours--the engine light does not come on! Also if I turn the key on but don't start the car--all I get is one blink from the trouble code light when I first turn the key ---that's it nothing more. I need to know what engine component is malfunctioning. Here is a list of what got tapped out by the thieves--Seat belt warning light, seat belt alarm, auto seat belt motor, key in ignition alarm, horn --the transmission must be key unlocked- and no codes. What in the region of the ignition switch needs restored- car will start and run just fine except the tranny needing unlocked ( now months latter engine trouble). Two of the disconnected wires are white with a green stripe- all the wires were on the bottom of the ignition switch under were the key inserts. 1991 Honda Civic Sedan
