this shoud answer your questions, unlike the very uneducated members who answerd s**t they have no idea about. its a writeup i did a little while ago, should give you a decent understanding. Yellowsi- please, do NOT answer tech questions that you have the correct answer to. your stupidity and ignorance is not welcome here, and is not helping the board out.
turbo- a turbo is a exhaust gas driven turbine, with the other end attached to a compressor. it uses a wastegate to regulate boost. one thing to note with turbines- they are built for a very specific rpm range where they are very efficient (meaning they produce a lot of pressure without making too much extra heat) and drop off quickly if not in their sweet spot- the center island on a compressor map. a PROPERLY sized turbo will offer you the most consistent power gains over the largest rpm range of any type of forced induction. with modern advances in aerodynamics, ball bearing center sections, etc, the "turbo lag" argument has gone the way of the dinosaur, except in situations where someone has purposely bought a turbo thats too large or wants to make unreal top end power at the expense of lag. because a turbo has a wastegate, the turbo can stay in its "sweet spot" rpm range for the longest time across the engine rpm band. turbos also do not have the parasitic loss associated with supercharger belt drives, but they do produce a small amount of backpressure.
roots type/positive displacment supercharger- this is your "classic" blower, which replaces the intake manifold. it consists of two interlocking "fans" which are more like semicircular lobes, that run at a constant pressure, and produce a constant flow of air (say the s/c has a pulley and set up for 7.35 psi, meaning the blower is forcing 1.5 times the normal air flow (.5 bar) of the n/a motor). these blowers usually have a bypass valve so they dont boost at idle. because the blower is not a turbine, it suffers from very poor efficency, at best, 60% (meaning 60% of the energy expended is used to pressurize the air, the rest is used to heat up the intake charge). they also suffer from the inability to use a normal intercooling system, further compounding the heat problem. the main advantage of a blower is ease of installation and tuning, espeically on a carburator. because all you have to do is replace the intake manifold, and use the new belt, install is easy. tuning is also much simpler because of the relatively constant boost pressure and predictable response.
vortech/centrithical (sp?)- this is, without a doubt, the poorest method of forced induction. it incorporates the worst of both worlds of the other two, along with almost none of the benefits. the vortech is the compressor side of a turbo, but is driven by a belt. remember now what i said about turbines- they are very, very picky about what rpm they operate at. on a vortech, the turbine is connected directly to the engine, so it has no way to get to its "sweet spot" until the engine achives sufficient revs (usually the last 1000 rpm or so of the engines rpm range). for the rest of the powerband, the voretch turbine is not spinning fast enough to achive much boost, and what boost it is producing is turbulent and overheated. there is NO way to make it not have either awful boost lag, or choke the motor on top end- the design itself prevents it from ever being efficient over a wide rpm range. vortech claims big hp numbers, which are usually correct- they simply use a huge compressor that gives massive top end hp, and reaches peak boost just before redline. on the street and the track however, this translates to a very poor feel, with the motor having no power for 90% of the rpm range, and then suddenly having massive power for the last 10%.
