I understand VSS is easy in first post I explained I already took it out , and it looms clean and solid ... I think wires , connectors , and relays are all located under MANI
You've contradicted yourself multiple times now, so somethings wrong with your explanations or you're simply mistaken. Yes, you
said you took it out but you did so by removing the intake manifold. I don't understand how you could've removed the speed sensor and still not realize how easy it is to reach it all without simply standing in front of the engine and looking towards the speed sensor from above.
How do you
think those things are under the intake manifold if you already reached the speed sensor before? They're not, at all. I should know when I've reached in and removed the plug by hand multiple times as I've removed the speed sensor multiple times only using a 3/8 rachet, extension, and 10mm socket.
