Wanted: manual shifter linkage, clutch lines and clutch fluid resevoir w/bracket
Status
Not open for further replies.
DavidR
Doing a auto to manual conversion soon still trying to find parts at a fair price.
086head
Alway browse craiglist and do you have a local pull a part. Glwb-and ninjia bump;)
DavidR
I might have the reservoir and bracket. I'll check for you and send you a PM
thanks, if you don't have that let me know what else you have available. I'm just gathering parts little by little keeping it under a monthly budget but the parts I do have are the clutch pedal, clutch master and slave cylinder so im good on those. i still need manual engine harness, manual intake for d16y8, tranny mounts and brackets (preferably with all the bolts, im not sure if the engine mounts need changing, shifter linkages with or without shifter. clutch hose/lines, manual brake/gas assembly.
minja lover
del slo
No problem man. I'll let you know tomorrow, I'm hitting my junkyard so after that I'll go through the box of the stuff I have and will let you know what I have left over. I'll also keep my eyes open for those parts when I'm at the junkyard for you. I did the auto to manual swap myself on my ek hatch. You don't need to change the engine mounts at all, unless they are bad. You can also keep you auto gas pedal and just swap out the brake pedal for the smaller manual one, which I did. I'd recommend buying the clutch lines and hoses new. I got all the lines, etc from majestic honda for just about $50 shipped if I remember correctly. I'll PM you tomorrow.
I don't know if you seen these, but these are what I used to help me with my conversion:
Parts:
http://www.clubcivic.com/board/showthread.php?t=157624
How to:
http://honda-tech.com/showthread.php?t=1337459
DavidR
Parts:
How to:
Thanks alot man, apreciate the links let me know what you find. Only part that scares me about the conversion is the wiring lol but from the research i've been doing on it it doesnt seem that difficult. I'm just tired of the boring auto, but cant find a decent looking 99-00 5 speed civic around my area all of the ones i've seen where junk
B18ctrb
What do you still need? I am parting out my 97 hatch
DavidR
lol I still need alot, how much for hydraulic clutch lines (lines only), clutch fluid resevoir w/ bracket and shifter linkage, I'm not sure if it matters what tranny the linkage is for but i need it for a ex/si tranny.
Intertwined
It's onski brah
what part of this are you looking for? just the reservoir? or the entire assembly?
Status
