what code am i getting
SourPanch
Project Smurf
im just saying cuz iv seen diagrams that my car is diff
RonJ
Does your intake manifold and EGR system look different from the DX that I just posted? How about the diagrams below? Is this how your DX engine bay is organized?
SourPanch
Project Smurf
those are definetly more close to home =)
so lets say i put valve (a) bak on the car and still hat probs. using those 3 diagrams what do i look towards or do 1st
thankz so much btw
SourPanch
Project Smurf
i just made sure all hoses were goin to right place. so far good
but the charcoal canister part is diff. it has the 7 hose. and 2 red fabric type hoses
SourPanch
Project Smurf
something else ive been wondering about. someone told me once the cel comes on it should stay on.
il explain
if i go outside. get in turn on . no cel.
i drive around the block...no cel.
i drive about 5 min sometimes more sometimes less.
from 3-10 min of driving
then the cel comes on.
i pull over chek codes
but if i turn car off and bak on cel dissapears till again 3-10 min of driving
just throwing that out there. cuz someone told me it should remain solid at startup
SourPanch
Project Smurf
and if that is a problem i did check under the hood fuses.
but i also thought maybe my ecu is at fault
which leads me to think maybe the ecu isnt giving my egr sensor or w.e the proper if any power at all.
just a lone noobs thought
RonJ
That's not abnormal CEL behavior.
And the ECU is almost always considered last after other components are ruled out.
SourPanch
Project Smurf
alright. i was just checking compadre =)
il kik that guy in the nutz and b like
"maybe ur ecu is f**ked f**ker!" =p
RonJ
Carefully check all of the EGR system vacuum hoses for leaks or clogging. Then do the electrical troubleshooting described in the diagrams.
SourPanch
Project Smurf
well i carfuly went down all the hoses every thing seemed in order. 21 had a big rip. but on tip. i cut off and put bak on. it wuznt the problem. ummm like i mentioned b4. the 2 hoses out of "charcoal canister" wear red and thick fabric type. thats correct right?
RonJ
... the 2 hoses out of "charcoal canister" wear red and thick fabric type. thats correct right?
I don't know.
In addition to inspecting each vacuum hose for damage and holes, you also need to remove them and check whether they are clogged.
SourPanch
Project Smurf
some wear very stingy and didn't wanna b removed lol. how much are all new hoses just in case i tear em?
or tips 4 removal
SourPanch
Project Smurf
alright this morning i removed all egr system vacuum hoses.
checked them all closely .
cleaned out
and replaced.
then put valve (a) on after overnight cleansing.
i drove around...5 min
cel light.
i pull over...code 1 only
i tiink " yes! finaly!"
i take my gf out and i explain and hav her check while i drive
again only code 1
(still happy)
its nighttime now and im taking her home and i hav her check one last time.
code 1 AND 12 again
SourPanch
Project Smurf
today i tried the exzact match valve.
same results only code 1
then after prolongd driving code 12 and 1
side discovery...my oxy sensor wire has been cut so code 1 should no longer b an issue
but 12 remains
