If that motor came out of a car that required a resistor box to run the stock injectors on the stock ecu then yes you need the resistor box.
If you run a civic ecu like a p28 that a lot of people use, then I would run civic 240cc injectors. They don't require a resistor box.
The thing to search for (I don't feel like looking it up right now) is to search what type of injector comes on the h23, its it peak and hold or saturated. Once you find that answer out then you will know if you need a resistor box or not.
If you need inline resistors they are 10ohm/10watt inline resistors and you need 4 of them. Or you can use a honda resistor box.
