What Turbo Size to use?
AjPetrarca23
im trying to find out what size t3 turbo to use for my SOHC ex setup that will be running 7psi. i know that some of the t3 turbos are way to big for my motor and dont even really make boost.
UPDATE!!
2slo4u
wait4me
if you want quick spool for a daily driver pick up a t3 with a .48exhaust housing
i have that for my b series and its a quick spooler and im sure with a d series it'll be even faster
TiiM iiS l3eAsT
Scamming Piece Of s**t
look for a 42/48 turbo......made by Garrett or AiResearch .....usually can be found on a saab
AjPetrarca23
.57 COMPRESSOR WHEEL TRIM
.50 A/R COMPRESSOR
.63 A/R TURBINE
that is what i have in my car now and it doesnt spool up like i want. will i see much of a difference if i get the 42/48.
got traction
i rock the sohc
im runin a t3/t4 .57 trim. full boost about 5,000 rpm...but thats on a block thats like 8.5:1 compression
xxsenceo89x
aka superman
.50 A/R COMPRESSOR
.63 A/R TURBINE
with the 42/48 i had 10psi by 3k with 8.5-1 compression
edit: dont shoot for a psi. 7psi on the turbo you have now isnt going to be the same 7psi as the one your going to put on.
AjPetrarca23
the turbo i have now isnt even making good boost at all. i thought it was too big for motor.
so i should get the 42/48?
2slo4u
wait4me
if you do get it you'll spool up quicker..but the top end will be pretty flat
TiiM iiS l3eAsT
garret is airresearch
well no s**t lol but some turbos say garrett on them and some say airesearch on them.....
what brand is your turbo.....i might trade you turbos.....im looking for somethen a lil bigger
djrenok
Titanium-Member
Same here, just throw in some vitaras and custom I beam rods to bring compression down to 8.5.1 and go with a 53 trim. thats what i got. Pulls hard from 4-7K
AjPetrarca23
So i put the 42/48 turbo in. its alot better but im still not fully satified. im untuned now. how much of a difference in HP will i feel after my tune.
codyllee
About 43.35 more whp.... i really hope you are not making any full-throttle pulls being untuned and all. Do you have a wideband to monitor your a/f ratios? Getting tuned will yield a big difference!
AjPetrarca23
i dont even really feel that much boost right now being untuned. idk what the prob. is everything is hooked up right with no boost leaks
toneekay
Rubbin on yo booty
is your motor built? most y8's dont have problems making power, or boost, or feel, or pull with a 57/63
AjPetrarca23
no its not built. ima just get a tune and see what happens. or just take it to someone who can figure it out.
toneekay
Rubbin on yo booty
^it just probably needs a good tune.. what turbo were you running before this one?
