Finally decided to make a thread
Things I need...
Cams ITR CTR or something similar to that profile
Cam gears AEM's new ones or whatever I can get a good deal on
Port match my intake manifold so It will match up with the 65mm TB
Bigger intake to fit the TB
255 fuel pump I still have an hx one :suicide:
Hondata Intake gasket
Things I already have...
Motor mounts :thumbsup:
I bought these right after I found out I broke my old mount in half
When it gets warmer out I will be pulling the motor to...
Clean it up
Port intake manifold
Install Hondata gasket
Install SI swaybar
Delete P/S pump and loop the lines
Install the new back motor mount
As of right now that's what I'm working on and all I can really afford right now
Previous parts...
Engine:
JDM GSR shortblock (b18c)
Approx 11.8:1 compression
B16 pistons
New rings
New bearings
New thrust washers
ARP headstuds
Cometic headgasket
New oil pump and tensioner
P28 ECU. S200 tuned by Pure Tuning
B16 second gen head.
Omni Flat faced valves
Omni dual valve springs
Omni retainers
Blox intake manifold
ITR injectors
JDM ITR red valve cover
B16 cams
JDM DC Sports header w/ 2.5" collector
JDM Omni test pipe
Apex'i World Sport 2 cat back exhaust
AEM CAI
AEM TRU time pulleys
OBX Underdrive pulley
AEM High flow fuel filter
Gates Racing radiator hoses
Gates racing 170 thermostat
Buddyclub 170 fan switch
Skunk2 weighted shift knob
Skunk2 spark plug cover
Aluminum 2-Core radiator
Spoon 1.35 Radiator Cap
65mm throttle body
Transmission:
JDM B16 hydrolic 5-speed transmission
ACT clutch
Clutchmasters flywheel
New axles
B&M short shifter
Energy Suspension urethayne shifter bushings
Exterior:
Black Tails
SIR JDM headlights
Custom Grille
Supension/Braking:
Arospeed coilovers
Tokico shocks and struts
Slotted and drilled front rotors (not sure what brand)
Front and Rear strut bar
Front and Rear lower tie bar
Audio/Electronics:
Sony Headunit
Blaupunkt PCxb652 front speakers
Pioneer Rear 2-way 6x9
Clifford alarm/Keyless entry
Things I need...
Clean it up
Install SI swaybar
Previous parts...
Engine:
B16 pistons
New rings
New bearings
New thrust washers
ARP headstuds
Cometic headgasket
Omni retainers
ITR injectors
B16 cams
JDM Omni test pipe
AEM CAI
65mm throttle body
Transmission:
ACT clutch
New axles
B&M short shifter
Exterior:
Black Tails
SIR JDM headlights
Custom Grille
Supension/Braking:
Arospeed coilovers
Audio/Electronics:
Sony Headunit
