yea in that link i posted it says you can use the 5-spd manifold.
5spd setups have a iacv on the back of the manifold, while auto setups have the iacv on the throttle body
if you plan to use an auto tb with it then you will still be using a 3wire setup and have to block off the iacv opening on the back of the manifold.
if you want to use a 5spd tb then you'll be using a 2-wire setup and youll have to get an iacv for the back of the manifold
