Right. Yea the look of their website doesn't bode well for their products. Again I was just curious to see if any active members here had experience with them.
I've had my mind set on the progress kit for several weeks now... if not months, since I first read the sticky about suspension setups. Their website, in contrast, is very informative and clearly demonstrates a company that is proud of and confident in a quality product. And, being that they're made in the US is a plus.
Civexspeedy, I've noticed you keep mentioning not to lower the Progress coilovers too low. Where did you get this information or what has lead you to warn people not to adjust the height on these particular coilovers too low? I'm just asking because the only information I found provided by Progress about recommended height was in reference to the 350/250 rate set of series II and I quote "This calibration rides well on uneven road conditions if set up at a reasonable ride height around 1.0" to 1.5" less than OEM." What other adverse effects would be caused by setting the perches at their full drop adjustments? I have a feeling I'll be ending up at the very bottom of these if I get them... that's why I ask.
I got this info directly from Progress. This is in their description for their CS-2 kit:
That, and it is from personal experience working with coilover setups and playing with ride height and spring rates on my own cars. Granted I am running Koni/GC on my personal race car and the race car my friend owns, but the logic is still the same. The lower you go, the less travel your shocks will have. Extended top hats help, but only so much and applications are limited. The lower you go, the higher the spring rates you will need (stiffer springs). A softer spring rate will allow the suspension to compress more. Meaning you will use more travel on the shocks which brings you closer to bottoming out/hitting the bump stops. Whereas if you have the same ride height and bump up the spring rates higher, the suspension wont compress as much leaving you with a little more "wiggle room" and/or not hitting the bump stops.
The Progress CS-2's come with somewhat "soft" spring rates. Since the springs are a little on the softer side, you shouldn't slam the car. If you do, you will most likely be slamming the bump stops on hard bumps/dips or even RIDE on the bump stops which is not good and pretty much renders your suspension useless. I'm sure you've read many times that the CS-2's are a great coilover both for improving handling, giving a good drop and in ride comfort. All of which is due to the "ideal" spring rates. The higher you go in spring rate, the more harsh the ride will become.
Here is a crappy little Paint drawing I did real quick to try aid in explaining what happens when you lower a car far too much when it is not designed for it. It's a slight exaggeration and obviously by no means to scale lol.
The left (all that's with red) is what your suspension should look like, roughly, if it is set at either stock or at a reasonable ride height. Notice how on the third shock with the suspension under full compression, there is still room to go. In other words, not bottoming out.
On the right (all that's with blue) is what a "slammed" suspension would look like. Even at a static state, there's hardly enough room. When under full compression, you either run out of room which you would then be hitting the bump stop or actually sitting ON the bump stop. Which at that point your shocks are useless since your suspension is no longer serving its purpose.
Hope that helps.
i had function and forms, and you adjusted the forks on the bottom to lower it. that way you kept full shock travel. mine was dumped on them, and they rode awesome
The more I look at the F&F suspension, the more I question it. I'd much rather have shocks with external reservoirs which would allow for full motion of the shocks without any compromise in function, build or quality. It's one of the exceptions of getting away with being super slammed, but it's out of the price range of the kiddos who dump their Civics for attention.
Right on. I'd be happy with a drop similar to yours. I intend on getting the 350/250 rated springs. Still, would extended top hats help to increase travel of the shock when nearing the lower end of these coilovers?
Another couple of questions: 1) For reference, what size tires and wheels are pictured in those photographs? 2) With the drop shown, how much thread was left on the body (how much lower could you have gone)?
Thanks in advance
Someone correct me if I'm wrong, but I don't think anyone makes extended top hats that will work with Progress coilovers. I've never seen it or heard of it being done. Theoretically, yes it would help, but only just a little. Ground-Controls extended top hats only get you 24mm (not even 1 full inch) of extra travel. It helps, but it's not
very significant. But, like I said, I don't think there are extended top hats for the Progress coilovers.
