ZC piston question
bizoneoeh
Ex-Gang Member
I've heard that if you swap the pistons from a dohc into a d16a6 that it will give you higher compression. How true is that and is it worth doing. I have my old zc and thinking about throwing the pistons from it into my brothers a6. I have to change the head gasket anyway so why not? Has anyone done this or know someone who has? I'd appreciate all the input you guys have, thanks.
MasterShake
Try this -> click
Tom
honda.co.jp
yes they will owrk, and very well from what i've learned in teh past, they've even shown good result in Z6's aswell.
bizoneoeh
Ex-Gang Member
do you know if I have to use the zc rods as well or just the pistons?
Tom
honda.co.jp
Not honestly sure about that part.
bizoneoeh
Ex-Gang Member
so does anyone know about the zc rods? Do I have to use those along with the pistons or do I just use the a6 rods with the zc pistons?
Tom
honda.co.jp
have seen many times that the rods to use for a DOHC ZC if you go aftermarket were the z6 rods, so i guess i'd have to assume the same in thinking that you'd be able to use teh zc rods in a z6.
bizoneoeh
Ex-Gang Member
thanks bro :thumbs up
Tom
honda.co.jp
just make sure you do a real intense search before you take my word, i'm pretty sure of what i said though, i remember when i was going to build my zc after i had bent that rod, and only thing i could find was that the z6 rods were the same dimensions all the way around, taht and being that you can use the rod and piston set in another d shoudl mean you'll be ok.
bizoneoeh
Ex-Gang Member
I knew a doOd here that knew alot about the swap, he actually had zc pistons in his a6 but I lost his number :(
Tom
honda.co.jp
Well good luck with this, and just let us know how it goes for ya.
bizoneoeh
Ex-Gang Member
:woot: I found the answer.
they both will work but the zc rods are thicker like a b-series.
Tom
honda.co.jp
You mean D series, lol.
bizoneoeh
Ex-Gang Member
yeah, I guess. I was just told that the zc rods are a bit thicker than the a6 rods
Tom
honda.co.jp
well if that's true then maybe mine shouldn't have bent the way it did, lol, damnit.
bizoneoeh
Ex-Gang Member
I guess :lol: I'll be asking my other boy about that too
Tom
honda.co.jp
i was fine at 7psi, but when i went to 10psi, taht's when i had problems.
