5th gen help
Jcal816
I have a 93 EX Civic and would like to swap in a B18C1 that has an OBD II, will the ECU swap directly into the 93 EX? I was wondering if I needed a different harness. please get back at me
Jeegz
Did sum1 say mud??
i do believe you need a new engine harness since your car is only OBDI.
RaYrAy
The engine harness will work fine. You 'll have wire the knock sensor separately, and you'll need a conversion harness for the ecu.
obracer12
you need a conversion plug, wire in vtec and knock.. its 3 wires.. easy
did a b16 swap... same thing... if you've ever picked up a soldering iron your fine
ReSpEcT954
Xclusive Importz
as stated before the engine harness is good just get a jumper harness of the internet for like $60 and hook it up!
