ok i got 2 new kicker compvx subs 10'' rated at 1200watts 600 rms 2ohms
Im having a hard time finding a right amp. id rather it be a little under powered then too muchand fry them.
also what way should i hook these up Parallel or Series wiring?
for deciding wheter to wire parallel or series, check this out and download your manual it should have the wiring diamgrams all there for you, if you dont have a hard manual already
http://kicker.com/Product_Manuals
usually you choose how you want to wire based on what your amp can handle.
if you wire up one 2-ohm DVC sub in parallel you will get a 1 ohm load. since you have 2 of these, if you wire both of them in parallel you will have a 2 ohm load. obivously if you choose this route you will need an amp that can handle a 2 ohm load.
if you wire one 2-ohm DVC sub in series you will get a 4 ohm load. since you have 2 of these, if you wire both of them in series you will get a 8 ohm load.
back when i used to have a 10" kicker L5 solobaric (square sub) with 4 ohm dual voice coil and i had it wired in series becuase i only had a 4 ohm amp (4 ohm DVC in series gives an 8 ohm load).
rule of thumb: less ohms = more load. so a 4 ohm amp will handle a 8 ohm load just find. obviously it would not be able to handle anything less then 4
