not from an automatic you didn't. I did an auto to manual in my dx 4 door to a manual gsr swap for my dd and you have to buy a conversion mount. I bought the AVID one for $135 shipped, The hasport one is a little more expensive, It is about $150-175 on ebay. I'd just buy the avid one. And btw, you have to have a conversion mount or chisel yours off and put on a manual one and then re-weld and refinish the area, but in the long run it is just as easy and cheap to buy the mount. Look into my auto to manual thread.i have 93 civic hatch b16a 5 speed, i use the stock side mounts with upgraded bushings, and no front mount, and same rear mount. i hope this helps
No it won't, look at the brackets off the frame, they auto bracket on the car goes up at an angle, while the manual one just goes straight out. I've done one, I know.if its just d series use a 5 speed l bracket and use the stock driver and tranny mounts everything will bolt up perfect
