wat is the best way to bleed the clutch...ive bleed it for ever and still have no pedal...
stealthy said:the way i do it seems to be a bit different than whats posted above and it always works great for me. so take your choice. get a helper. person inside pumps the pedal, person outside maintains a full fluid level and works the bleeder. if it becomes empty or low, you will have to start all over.
pump the pedal til its hard. put foot on pedal with pressure to put it down (it wont move, bc its too hard). open the bleeder til it all comes out (the pedal will go to the floor). pump the pedal again til it gets hard. and repeat.
rinse and repeat, rinse and repeat. do this til all of the air is out. voila.
i see what you are saying. ill try it like that next time and see how it goesJR-Style said:the only bad thing about this method is it makes big bubbles turn into small bubbles, makes them harder to get out, i normally do it like this on brakes, but for honda clutches i use the other way. but if it worked good for you, who knows, maybe will go good for him too.
