So i dropped in the boosted Y8, NOTHINg fit perfect haha everything had to be bent, custom fit. But got it in and plugged up NO BOOST LEAKS, nothing EXCEPT.......
With the stock ECU it fires up and I have to hold the gas pedal down to keep it running. Bogs out when u let off....
Then I threw in my Neptunes RTP ecu and it doesnt start, just clicks over n wont fire up.....I also downloaded someones tunes basemap and still doesnt work.
No then i smelt a ton of gas, i pulled out the NGK plugs and bottoms are black and they smell like gas.....So what can this be?
and why cant I get this thing to idle??? I changed the setting in RTP, like injector size, trim, start up fuel settings etc and still wont go...
Also i have a blox adj FPR, which i told i should take off, but will that fix my problem?
