well i have the hx ecu but don't have any harness or wires from it i was told everything will work from my \
y8..........and i am goin to use the y8 headers with the o2 sensor that is already in it from the y8 will that be ok?
Use the ex wiring harness and o2 sensor, but you will need to get a tuned ecu (p28 I think) and tell the tuner that you have an hx head and vtec needs to kick in earlier. Remember another guy posted that the hx head only uses one valve until vtec kicks in, so if you use an ex ecu, you'll only be using 1 valve until 4800 rpms and it will run like crap after 2800.
The hx ecu needs a 5-wire o2 sensor and egr valve, so you'll get cel lights for those and the motor will go into limp mode to protect itself (thats what I've read antway).
You needed a chipped ecu to get around all these little differences between the ex and hx.
